重复的结构如何快速建模
我现在在做工业建筑中的通廊,一个通廊中有好几个相同的桁架,但是这些桁架并不好选中进行复制,如何快速选中相同的桁架?
  • Hello Zhang Wenchao,
    If you want to use a perticular Truss assembly at many places in your model, I suggest you to save the Truss of your choice as a template. In this way, you can recall the same Truss settings at many places of your requirement in the model.
    1) In the Truss dialog box, set all the parameters
    2) In the Templates option, create a new folder, and save the current Truss as a new template
    3) Later, wherever in the model you need this Truss, you can use the Truss command and recall these settings from the Template manager
    Also, you can refer the below Wiki link for assistance on how to create a Truss -
    Alistair Lobo
Reply
    Alistair Lobo
