Good morning,
I have created a concrete approach slab with rebar using constraints so that we can modify the roadway width and the rebar can move with the object.
The issue is when I go in to change the roadway width constraint the program freezes and an error occurs every time.
Has this error occured for anyone else?
Attached is a picture of the error that occurs when changing with constraint for roadway width
Hi Jeff,
Thanks for addressing this issue to the Bentley Community.
Can we have your file so that we can investigate and can see why this is happening?
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Sandip,
Here is the file.
3D Approach with bars.dgn
Thanks Jeff for your update. I will look into this and will come back to you soon.
I took a look at the file and it looks like the profile you used to create the slab is not fully constrained, this results in errors when trying to edit a variable. I've attached a modified version of the file in which i fixed the profile for you to review.
You may have to modify the rebar placed for it to update along with the slab.
3D Approach with bars_bentley_modified.dgn
Hi David, thank you for looking at the file.
I have taken the file that you attached and added bars into the slab. When I edit the roadway width variable the object moves but the rebar does not stretch with the object.
I have placed the bars using associative intersection lines that I have created. Should the rebar follow these lines and stretch with the slab as well?
