Dear Support,
I would like to clarify that, Can we detail the post tensions for bridge using ProConcrete? If yes, Kindly provide your advice.
Balaji
Hello Balaji Gunasekharan,
Thanks for posting your query in Bentley Community Forum.
Can you please explain this in more detail so that we can give you better solution?
it would be nice if you can share some images also to explain t=your requirement.
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Sandip,
Further to your email, provided below is a snippet of similar detail which required to be modeled.
PLAN View
Basically, the blue one is the Post tension rebars which has waved profile in elevation.
3D View
Something like this?
Please give some advice how to detail this in model. Thanks
Best Regards
