Is there any way to specify the insertion alignment while using irrefular dispatch reinforcing (like single rebar distribution)? I have varying stirrup bars that I have defined its properties with a 2" cover but when the rebar is distributed the alignment of the rebar is at the center of my "guide line" which gives me less than my 2" cover due to half the bar thickness.
Regards,Sandip KarProduct Engineer - Bentley Systems
Answer Verified By: Devin Bush
That is correct, I will have to keep that in mind on future projects. Thanks
