Proconcrete single rebarset bars not adjusting with variable constraints
Hi
I am using Prostructures CONNECT Edition Update 3 - Version 10.03.00.58
I have placed a simple slab using the 2d and dimensional constraints. I then used the Face Based Rebar tools local variables with "Associative Extraction" and "Associative Interaction" and used these lines to place reinforcing.
  • When I use tools such as "Single Rebar" to place the reinforcing from these lines the reinforcing moves and adjusts when I change the local variable.
  • When I use "Single Rebar Distribution" to place reinforcing from these lines the reinforcing DOES NOT move or adjust when I change the local variable. Am I not doing this correctly or is the "Single Rebar Distribution " tool not set up to adjust with the variable?
See video.
