I'm trying to place gusset plates in the 3D model, found them in help, but nothing about how to place them
Hello Mr. Davenport,
There are various methods to place a gusset plate.
Either it can be done full automatic like in the dynamic bracing command, or half automatic with already set bracing rods like in the gusset plate command, or manual with a plate derived from a polygon with the exact placement and form you just need if the others don´t work.
Maybe a screenshot or a Modell would be good to have with the situation you are just in.
Best regards Johannes Michalowsky
Bentley Structural YouTube Channel
Bentley Technical Support
User Success Support - Bentley Systems
ServiceRequest Manager
Answer Verified By: Steve Cocchi
