RE: [Subforum Structural Modeler / AECO Structural Forum] Placing Gusset Plates
Johannes,
Thanks for the reply, we do not have ProSteel.
We are evaluating the AECOsim package that has Structural Building Designer V8i.
The option you showed does not appear when placing cross bracing.
Al D.
From: Johannes Michalowsky [mailto:bounce-Johannes_Michalowsky@communities.bentley.com]
Sent: Tuesday, March 03, 2015 3:09 AM
To: SubStructuralModellerAECOStructural@communities.bentley.com
Subject: RE: [Subforum Structural Modeler / AECO Structural Forum] Placing Gusset Plates
/cfs-file/__key/communityserver-discussions-components-files/343340/image001.png
Message from Bentley Communities
/cfs-file/__key/communityserver-discussions-components-files/343340/image002.jpg
Hello Mr. Davenport,
There are various methods to place a gusset plate.
Either it can be done full automatic like in the dynamic bracing command, or half automatic with already set bracing rods like in the gusset plate command, or manual with a plate derived from a polygon with the exact placement and form you just need if the others don´t work.
Maybe a screenshot or a Modell would be good to have with the situation you are just in.
Best regards Johannes Michalowsky
View online
You received this notification because you subscribed to the forum.  To unsubscribe from only this thread, go here.
Flag this post as spam/abuse.
http://communities.bentley.com/notification/read?NotificationId=147b501a-11d8-4869-b922-471fd4d4855e
