Hello Guys,
I have an issue that I do not know how to solve and I was hoping that you could help me.
Lets say I create section X (solid round with diameter 100) with the help of "StructuralShapesTemplate.xls", export it to XML and then draw some members with this section.
After drawing 50 members I realize that section X should have been solid round with diameter 200. I go in the "StructuralShapesTemplate.xls", modify the diameter, export it to XML and then go in the model where I drew members with X section.
I would like all the members drawn with X section to update from 100 diameter to 200 diameter. How do I do that?
Your help would be highly appreciated.
Cristian
Hi Christian,
If I correctly understand the situation, I think selecting the members and following the right-click process below should do it:
Answer Verified By: Steve Cocchi
