Hi guys, I am doing manual connections as i feel it faster than using macros, but the problem i now is, during creation of assembly drawings and trying to edit them, i can't do a separate line of dimensions for shear plates, stiffener plates, gussets etc even if i already assign them in the "description" as shear plates, stiff, gussets, etc. i am not sure as i am not an expert on prosteel if it has to do with the logical links? as when using macro it will create an active loglinks but if manually done it will not? if so, is there a way i can do an active loglinks even if connections are done manually? would appreciate to accept your thoughts guys.thanks a lot.
EDISON ROAD model.dwg
