I have an issue where text that I have moved, to avoid clashing, moved away from its position the next time I run the extraction. Widgets are fine, just seems to be text. I'm also have an issue with some text on angled elements not coming in at the 50% mark . I'm using centre/bottom justification to keep the text central, but it's not coming is at the position set by the rule. Doesn't seemto be a problem with vertical and horizontal members.
Any help appreciated.
bump
slight nudge :-)
bit more of a push now :-)
I came across something similar in BBMS, but not BS. Does it seem to be file or rule specific?
Seems to be more on elements that are on an angle Steve, as well as section names that have been moved. I'll snap a few pics and post.
