Bentley Structural Modeler Install
Hi All,
I've been trying to install Bentley Structural Modeler with Microstation SS2 and get an error that the correct version of Microstation isn't installed even though it is. The install has worked fine on co-workers machines with the same software versions as me so it appears to be an isolated problem.
I have tried uninstalling Microstation, running a registry clean, then reinstalling everything without any luck.
The only difference I have noted is that when I ran the Bentley Structural installer for the first time it required a restart part way through the Microstation update install that the other machines have not required. At the time I got the impression that the restart was interrupting other active dialogues but as the restart seemed to be a part of the install process I clicked it before realising this.
Install file versions:
Setup Prerequisites 08.11.07.03_en.exe
ms081107443en.exe
stf08110794en.exe
Error Message:
Microstation installation of compatible version was not found. You must first install a product of a cersion within this range: Microstation V8i 08.11.07.171 - 08.11.99.9999
Installer Log File:
Reading system Properties;Date="20135204";
Loaded package: MicroStation Update;Date="20135204";
Analyzing property: VersionNT
 Value is: 502;Date="20135204";
Registry value: DisplayVersion :08.11.07.443;Date="20135204";
Analyzing property: DisplayVersion
 Value is: 08.11.07.443;Date="20135204";
Executing condition: DisplayVersion;Date="20135204";
Set to Install;Date="20135204";
Loaded package: Microsoft SQL Server Compact Edition  - English;Date="20135204";
Analyzing property: VersionNT64
Registry value: DisplayVersion :;Date="20135204";
 Value is: ;Date="20135204";
Loaded package: Windows Install 3.1;Date="20135204";
Analyzing property: VersionMsi
 Value is: 4.05;Date="20135204";
Analyzing property: Version9x
Executing condition: VersionNT;Date="20135204";
Set to not fail;Date="20135204";
Executing condition: Version9x;Date="20135204";
Executing condition: VersionMsi;Date="20135204";
Set to Skip;Date="20135204";
Loaded package: Microsoft .NET Framework Version 3.5;Date="20135204";
Registry value: Version :3.5.21022.08;Date="20135204";
 Value is: 3.5.21022.08;Date="20135204";
Executing condition: Version;Date="20135204";
Loaded package: Microsoft XML Parser (MSXML) 6 SP 1 (32 bit);Date="20135204";
Registry value: PatchLevel :6.20.2016.0;Date="20135204";
Analyzing property: PatchLevel
 Value is: 6.20.2016.0;Date="20135204";
Executing condition: VersionNT64;Date="20135204";
Loaded package: Microsoft XML Parser (MSXML) 6 SP 1 (64 bit);Date="20135204";
Executing condition: PatchLevel;Date="20135204";
Loaded package: Microsoft Visual Basic for Applications core;Date="20135204";
Analyzing property: Vbe6DllPath
 Value is: 6.5.10.54;Date="20135204";
Executing condition: Vbe6DllPath;Date="20135204";
Loaded package: Microsoft Visual Basic for Applications localized;Date="20135204";
Loaded package: DirectX 9c;Date="20135204";
Registry value: Version :4.09.00.0904;Date="20135204";
 Value is: 4.09.00.0904;Date="20135204";
Loaded package: DHTML Editing Control for Applications;Date="20135204";
Analyzing property: Default_DhtmlFileVersion
 Value is: 6.1.0.9247;Date="20135204";
Executing condition: Default_DhtmlFileVersion;Date="20135204";
Loaded package: RAM 3D Viewer;Date="20135204";
Registry value: Version :14.03.02.00;Date="20135204";
 Value is: 14.03.02.00;Date="20135204";
Executing installation command: C:\BentleyDownloads\Structural_08.11.07.94\setup_microstationupdate.exe /c:"microstation_08.11.07.470enupdate.exe /qn" /q;Date="20135204";
Executing command: C:\BentleyDownloads\Structural_08.11.07.94\setup_microstationupdate.exe /c:"microstation_08.11.07.470enupdate.exe /qn" /q;Date="20135204";
Command exited with code: 0;Date="20135204";
Executing installation command: msiexec.exe /qn /norestart /i "C:\BentleyDownloads\Structural_08.11.07.94\sqlserverce31-en.msi";Date="20135204";
Installing package: C:\BentleyDownloads\Structural_08.11.07.94\SQLServerCE31-EN.msi with args: ;Date="20135204";
Executing command: msiexec /i StructuralInstall.msi  FROMLAUNCHSETUP=1 ;Date="20135204";
Command exited with code: 1603;Date="20135204";
Thank you very much for your time,
Philip Las Gourgues
Parents Reply Children
