I have 2 issues
One creating a template that works and two the generic template does not show all the fields in the structural Attributes pop down
I assume any new template must have link to the fields within the structural Attributes pop down somehow.
If I can be pointed to a paper that explains this in layman's language I would very much appreciate it
Tony
Can you elaborate on what you'd like to see?
beam / column size
ID number
TOS
stud crs
pre camber
end connections
Something like the attached? If so, you can drag around the existing columns in DataGroup Explorer to match the layout you're looking for, and drag columns upward to remove those you dont need to see. Then choose Schedules > New to save that layout.
For properties that do not currently exist, like TOS, I'd imagine you'd have to add a custom DataGroup Property since TOS is a geometric attribute and not part of the member per se. Search the help for "Establish DataGroup System Catalogs – Tutorial" for more information on creating DG properties abd catalogs.
