Hi
Is it possible to work in a model where the working units are mm:mm and display the Top of Steel height in the drawing rule as Metres???
So a top of steel height is required to display as 4.750m instead of 4750mm
John
I think this might be possible using a custom VBA for the label's Format, however, I'm not a VBA guy so would have no idea how that's actually done!
