Hi All,
Please see the attcahed file for your understating .......
Rds
Devaraj.S
I guess you want to extend the column to the beam, correct?
Try to use the Modify tool 'Extend/Trim to Object'. Screenshot below:
Where you want to add stiffener plate (at top beam, collumn)? or make connection beam/collumn with plates? Check the 'ConnectionCenter' for existing connections (menu ProStructures->Steel Connections->Miscellaneous->Stiffeners).
Hope this helps.
Regards,Darius
