Excellent !!!!! Mr Darius,
Yes, you're right. I am trying to add column in some of angle in vertical axis. i just tried to rotate the workframe,but i don't get the results. please explain more.
I have completed the rigid columns with your supports and i would like to add some bridge crane lattice supports an inside of the building. I have lot of queries.
My questions/ clarfications are given below please clarify this ...............
Ques. No : 1
Work Frame :
Already given the reply.... but,kindly give the rotation snap shots in step by step?
Ques.No:2
Bracing Connection :
How can i Connect the vertical and dygonal bracings in single plate with bolted?
Ques No :3
Anchor Bolt:
How can i show the anchor bolts in base plate ?
