Group Position Number in Navisworks Manage
Dear All,
         Does anyone have a way of getting the Group position number attached to each part when you bring it through to Navisworks Manage?
Thanks in Advance.
Shrinivas Jadhav
  • There is a possible solution if you are using Prosteel with AutoCAD.  In AutoCAD, with Prosteel loaded, try using the NWCOUT command to export to NavisWorks NWC format.  This should send the Prosteel properties to NavisWorks.  However, I'm not sure if position number will be included??
    Answer Verified By: shrinivas
