I have 2 users on SM 08.11.07.94 that cannot export a complete STF quantity report. It looks like all of the structural members are being left out. Everything else about SM seems to work correctly. Microstation, SM and Excel have all been reinstalled/repaired and nothing changed. No error messages show up. Attached is the incomplete report, a complete report, and the DGN they were both generated from.
Hi Mdiehl,
Is this about Structural Modeler?
Yes. Structural Modeler V8i (SELECT series 1).
Delayed response...
Can you check whether using the attached Excel template helps? I believe there may have been an issue with Structural Modeler V8i when using older templates.
Answer Verified By: Steve Cocchi
