The coordinates I'm getting in curves with radius less than 1000m and the transition curves are not coming on the alignment.
Please help.
Yamini
How did you get the graphic in AutoCAD? Is the graphic in AutoCAD an arc or a polyline?
A simple test is to first check in Rail Track:
I don't get any difference. So should be the same in AutoCAD in an arc. For a transition it depends on the stroking but you must ensure to have a vertex at least each 20m to be able to compare the same things.
Answer Verified By: Yamini Dasari
Hi jpln,
I have extracted coordinates at every 20m as a report and imported the same coordinates as horizontal alignment. In transition locations the imported alignment is not coinciding with the alignment from which the coordinates are extracted.
