All
I have a bit of an issue - more of an annoyance with annotating turnouts/crossovers in my vertical profile. Would appreciate any help
Am using the "Display Turnouts In Profile" tool to display points and stationing for the physical toe (.1), the IP (.2) and the location of the LLS. This works fine for a turnout when annotating inline using the "Offset above Turnout" drop down part of the dialogue box. See image attached "Turnout Anno Profile Inline"- I am ok with this during design work in progress.
My issue is that for design presentation on formal drawings, I want to show my turnouts at a fixed offset from the bottom of the profile. I do this using the "Fixed offset from profile" part of the dialogue box. However, the LLS point and station are still annotated above the alignment as opposed to the fixed offset. So I get something like the attached image "Turnout Anno Profile Fixed Offset", which is less than ideal
Is there a way for the this to work the way I want it to? with the LLS location brought inline with the Toe and IP positions at a fixed offset from the profile?
A
