SIG Virtual Workshop: Bentley Rail - Library Building Guidance with Power Rail Overhead Line
Join Bentley's J.P. Gauthier and Graham White on Wednesday, February 22, at 10 a.m. EST and 5 p.m. EST for the next Bentley Rail Special Interest Group (SIG) workshop, Library Building Guidance with Power Rail Overhead Line. Register today!
These complimentary virtual workshops are designed with you in mind and structured to keep you informed, engaged, and working optimally. Discussion and demonstration will include how to:
    • Combine survey, design rules, and operational requirements to generate outline overhead line designs
    • Use engineering workflows to produce height and stagger values for wire runs that take into account spatial constraints on equipment and the geometry of the underlying track
One Professional Development Hour (PDH) will be applied to each attendee’s Bentley Transcript for self-reporting.
