We are pleased to announce the availability of OpenRail Overhead Line Designer, the first comprehensive contact line design modeling application for rail electrification.
Co-developed with Siemens Mobility it includes all the functionality of OpenRail Designer with the additional detailed design and analysis capabilities of Siemens Sicat Master to deliver BIM compatible models and support the creation of Digital Twins.
The new application handles a wide variety of overhead line electrification design cases, such as long-track segments and complex yard/station areas and tunnels.
OpenRail Overhead Line Designer enables design teams to effectively manage their project compliance and create their own standards and user-defined libraries with easy-to-use editing functions or use built-in Siemens Sicat libraries.
Adapting to virtually any rail design and maintenance workflow OpenRail Overhead Line Designer is suitable for a range of electrification projects including light rail, metros (transit), heavy rail, and high-speed rail.
Highlighted Capabilities
Below are highlights of OpenRail Overhead Line Designer’s capabilities. For further information on features and capabilities, access the links provided in the Supporting Materials section.
You don’t work in a silo and neither should your software. From integrating existing track geometry, to working with other project partners, OpenRail Overhead Line Designer makes it easy to work with different data types, disciplines, and distributed teams.
Reduce design time, cost and risk while adhering to contract requirements on time every time with user definable design rules that allow engineers to focus on the design process.
Work smarter, reduce risk, and avoid rework with user friendly design automation tools, and digital workflows that ensure changes to masts, wires, structures and assemblies are all updated in real-time.
Whether you need to produce traditional 2D plans and reports, advance to 3D modeling or support wider digital transformation within your project or organization, OpenRail Overhead Line Designer does it all.
To learn more about this product release the following links provide access to supporting information :
For additional information please contact your Bentley Account Manager or members of Product Management Team
Ian Rosam
I have issues with installing, it seems to be problems accessing the URL https://payloadresolvesvc.bentley.com/api/Resolver/ but I have not this problem with other products, in fact, I have uploaded OpenBridge Designer from Connection Client with no problem.
