Greetings from Croatia :D
I have a problem with saving geometry file after a certain action I did.
Let's start from beginning:
I have a geometry file which contains a several horizontal/vertical alignment a turnout and COGO points. When I delete multiple COGO points with a "Delete COGO point" tool I can't save geometry file becuase an error messaga pops up "Error writing to file" and whne exiting PRT says that it is failed to open some file in program directory on C drive. I have checked, file is there, and I didn't changed it or moved it. And this is not happening when I make some other change in geometry file.
More details in attached pdf file.
Did someone had similar problem or knows how to solve this?
It would be a great help if someone could try to do this with my geometry file to see if there is a problem with .alg or something else is on the way.
Thank you!
Hrvoje
https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/5921/4760.Cakovec_2D00_Virovitica.alg
But did you managed to save it? I checked all of this... I don't have any path defined for drainage structures and I am an administrator. I tried all solutions you suggested and didn't worked. As I already wrote, if I make any other change in this geometry file I can save it without any problem. Problem begins when I want to save .alg after deleting COGO points. That is what is strange in this situation... Robert thank you for replying...
Hi Hrvoje,
yes I save it - no problem...
If you can, send me screeshot from your File > Project Default ....
next: try use another m_structures.dat - may be original file is damaged.
...or: try to create new ALG file and copy alignent from original ALG file - may be there is something in the file....
Robert.
