Dear Forumi need to place Signals in BRT Signal Sighting via a Location Anchor within the Furniture Placement Toolbox. I want to place distance wise along an ELR and then place the signal offset from a particular alignment. I am able to do this perfectly via importing a whole csv sheet which has just this data on it and pon importing the sheet all other values are filled in instantly and perfectly. i cant get it to work properly for single signal placement with the tool.i cant use the import method each time i need to add another signal as this import method resets all the levels i have set for all individual signalsupon toggling Location Anchor on, I select my ELR in the left hand set of tool in Furniture Placement Tool but when i type in a Station, no displacement appears so its not able to set the furniture location in the right hand set of tools. ,invalid. appears in both Displacement and Furniture Location Station.ive played with picking a point via the tool available on the same dialog, but this appears to be for furniture placement where we have a particular spot to place it. i have an ELR and offset, i dont have a point available.am i doing something wrong. im following everything ive been told, and shows in the Training Manual. does anyone have any exact workflow in using thio dialog placing signals via Location Anchor
