Hi all
I working through an old workshop manual which I think is pretty good however I was having trouble with the following:-
Apparently in the Edit /Review Horizontal Regression Points menu, if you right click I get a up pop menu with the following options:-
Insert, Edit, Delete
But if hold down the Ctrl and right click I should get a different pop up menu with the following command:-
Select All, Select None, Delete Last Element, Add Spiral, List All
The problem is that when I hold down the ctrl key and right click nothing happens - does anyone experience the same problem?
Below is the extract from the workshop manual
Answer Verified By: Stewart Souten
