Is swept envelope analysis carry the calculation of Midthrow and End throw of the vehical.
If yes, what is the procedure and please attach some videos pertaining to the issue.
Thanks in advance.
Hi jpln,
I too have a similar concern if the swept path analysis is considering centre and end throw i.e the overhang of the vehicle due to its rigid body shape.
Formulae:
Thanks in Advance
Yamini
Yes it does. I have never checked the result but theoretically the tool is moving a rigid volume along the alignment at defined interval, also using profile and cant. But if profile is flat and you don't have cant, then result should be the one described.
Thanks, jpln for the answer
