Problem in curve widennig
Hi Everyone,
I am using PRT series2.When i am applying curve widening and point of control to both line(up and down line), for RH curve it is fine but wherever LH curve and Track distance is more than 6m(which is in template) i'm not getting proper curve widening. For Example,
track center(normally)=6m,
track centre to cess-3.93m, with curve widening=4.23m
when we comes to curve location track centre is slightly varies. In this situation,i given points control to both line which increases the track centre in cross section whatever the distance increases that compensating the curve widening means if the track centre is 6.1, my cess distance is 4.13 instead of 4.23 in curve loaction.
Please suggest me any solution for this problem
