Hi all,
i am using BRT series 2, while annotating the cross section the offset distance of ground profile level not getting exactly as i wants means the offset must start 0.000(it has to show) exactly below the down line. I need two offset distance below the up and down line as 0.000 and 6.000. Please give suggestion to overcome this
Please see the attached cross section also
client sample also attached here you can see the offset distance 0.000 and 6.000 in this drawing. Same thing how can i get? anyone please clarify me
It seems like you haven't imported lines in existing DTM or Ground surface. Import required lines into your concerned DTM (While import elevation option need to select from Surface) and don't assign any feature properties to that lines ... it will reflect again in cross section generation (add as a point feature style). While annotation select feature style and choose what features required to annotate. (Keep in mind Frame Offset starting point distance while annotate).
Answer Verified By: Ravisankar Raja
Sample Ground level with Offset distances FYI.
Here is the Video showcasing annotation of cross section
