Hi all
I tried to annotate distances between event points in horizontal alignment.
Please guide me whether it is possible to annotate?
what ever the way by value or dimension line, i want to represent distance between two successive event points in PRT SS2.
It looks like I missed this one. Anyway there is no command to annotate distance between event points. You can annotate the station at event points. You can annotate distance if there is a link between points so typically features or alignments. But it can be a workaround if you want to annotate the straight distance, if it is the distance as a difference of stations then I don't see any automatic way to do it.
Answer Verified By: NAVEEN BANDARU
Thanks for your reply JPLN.
