Incorrect slope of cut in template
Hi All,
I model in Bentley RailTrack V8i (Select Series 2). I have problem with templates which include component with End Condition. This component finds existing terrain (Triangulated model from RailTrack). I set up slope of cut 1:1,75 (57,14 %).
But sometimes I have problem with different slopes from the same templates. For Example, unpaved ditch:
But on another place with the same template - the slope is really different!
Didn´t you have any experience like this?
Another problem with that - I have for example 8 components in the same place - It could be connected with that.
Thank you
Petr Vocedalek
