Hi everyone. I have a railway alignment and also many turnouts. I had to revise my alignment's end part and copied that horizontal alignment with different name. I created the new alignment's profile and tried to annotate the turnouts but it didn't. How can i make it annotate or should i re-create all turnouts on my new horizontal alignment?
Thanks.
Because the original alignment on which you created the turnout still exists in the geometry project, the turnout remains attached to this alignment. If you delete the original alignment and if the copied alignment is exactly superimposed to the original at the location of the turnout, then the turnout will be linked to the copied alignment.
So in your case you should copy the entire geometry project rather than the alignment.
The turnout locations are exactly the same. I copied the Geometry Project file, deleted original alignment and tried again but it didn't annotate it.
did you check the connection using connection editor ?
