Hello everyone!Couldn't find forum for SS2 so decided to put that issue/question in here.Have anyone had such problem/error as on attached image while trying to produce reports (Tools->XML Reports) in BRT SS2? After clicking OK reports window appears, but it's empty. Each time I try to use one of these tools new error with different file number/name shows up. We have even tried to copy files from my teammate machine where it works fine.Checked on two different computers (one with Win7 and one with Win10). Soft version - BRT SS2 V08.11.07.685.I'd be grateful for any help or idea!Regards,GH
Try to change the Regional settings on your PC.
(BRT V08.11.07.685, on MS, SS 2)
You mean Decimal symbol to be set as '.' instead of ',' or sth else?
Check all things. You have one working station, try same settings.
What you mean 'You have one working station'? We have separate computers.
Seems that all settings are the same, but I will double check it.
Control Panel>Region> on tab Formats > in Format select English (United Kingdom).
