How to change category of imported alignment from Road to Rail in Openrail Conceptstation?
When importing track alignment from Bentley Rail Track into OpenRail ConceptStation via .xml, the category of element appears to be set to "Road" by default. See image attached.
How can the category of an alignment be changed from Road to Rail or Track?
Strange thing is track template is applied to the imported alignment but is categorized as Road. But the track bridge tool does not work on alignment since it is categorized as road.
Parents Reply Children
