OpenRail Conceptstation - Bridge located incorrectly on imported alignment from .alg
When adding a bridge to a track alignment imported from .alg, bridge deck and substructure is located several hundred meters away from actual bridge deck. But, when adding a bridge to a track alignment developed natively within ConceptStation, the deck and superstructure are correctly aligned.
Is there any solution for this issue?
See attached screen shot.
Parents Reply Children
