I'm using PowerRail Track SS4 and it seems that my ITL file has been corrupted and, somehow, all the templates of the ITL has their constrains with value 0.
Do anyone knows what is reason of this?
Thank you in advance,
Carlos Molina
The ITL was completely ok the last time I opened it and I don't know what happened. See the file attached. I also attach the file propperly working before the lastest changes.Without bug.itl
Bug.itl
I
Hi Carlos,
Sorry for what happened. I really don't know how you get there. The feeling is something that happened with decimals because I only see zeros after the decimal separator.Do you think possible that it has been edited with comma instead of Point as decimal separator in the regional settings?
Hi jpln!
Thank you for your answer. The file, hosted in ProjectWise, has been edited several times with no issues so far. But, suddenly, after exporting from ProjectWise, it has that shape. At least in my computer it hasn't been edited changing the regional settings...
Maybe checking the audit trail of the itl could identify an event related to the issue.
I got the same problem as Carlos third time in the last month. How to solve this issue?
Same story!
I suspect that the whole problem causes a decimal sign "." or ","
Tip: do backups or export ITL to XLS - migration utilities
