Importing A Vertical Design From Design Route Software Into BRT
Hello all
I was wondering if any could help shed light on the following:-
I have completed a horizontal design in BRT but the vertical design has been done by someone else using software called Design Route.
The vertical curve information from design route is as follows:-
I wanted to use the Text Import Wizard to import the Design Route vertical profile into BRT but I am struggling.
I was wondering if anyone had any experience in importing Design Route data into BRT and if so could you explain how it is done or give an explanation on how the data in the text file should be labelled inorder for BRT to correctly import the Design Route vertical profile.
Can anyone help?
Any help will be greatly appreciated.
Thank you.
Parents Reply Children
