How can I import cant from an alg file?
Thanks in advance.
//Christiaan
Hi, unfortunately there is actually no way to import cant from ALG to Openrail Designer
Then the question is how to import cant? Can this been done with an xml file or something else?
We made track design with cant in Power Rail Track and if you want to use this design in Open Rail you don't want to recreate the cant especially if your design is more the 10km.
Best regards,
Ariaan
Hi Jean-Pierre,
Can you please put this on the high priority list! We have a lot of projects already in Railtrack ALG files with Cant and we can't use the data in the new release or we have to rebuild the all the data in ORD
Thanks in advance
Should come with Update 1
Thanks, great to hear!
