I made a quick test in OpenRail Designer with a simple geometry (consists of 2 straight lines and a curve R=900m and transition curves L=80m). This is the parameters before the cant is created:
My questions: (1) Can I change the "Equilibrium constant"? We noramally use a fixed value: 11.8. (2) Is there a setting for rounding the "applied cant" to f.x. 5 mm? This option was in PRT SS2/SS4.
The result of the calculated cant is shown below:
My comments/questions: (1) The unit for cant should be mm (not cm). And it'll be great if the unit is only shown in the title line and not in every cell (it'll make it easy when exporting to f.x. excel). (2) Can I show the result with fixed decimals? (3) how do I rearrange the order of the fields?
Thank you!
LiPeng
The edit cant table is using the design file setting. So if you change the working units (sub units are used) accuracy and remove the unit label (mm) you will get the expected result. You can choose the columns displayed and order by right clicking on the header and go to show colums>More...
I don't see yet variables to set cant rounding and equilibrium constant
Rounding should come with update1
Hi jpln,
I posted a few more cant editor queries in the EAP forum, could you give me an update on these?
Hi;
Jean-Pierre already answered some questions, let me add to them. But first, I want to mention, we are not in a 3 month release cycle, that is we will be able to address the requirements much sooner and will be adding functionality incrementally. And your suggestions are very important for this process. So thank you for your feedback, we are looking for more.
We will have cant rounding with the first update.
Equilibrium constant is calculated based on the rail gauge with using standard methods. You can change the gauge to the value you use and you should end up with the same equilibrium value (11.8).
Thank you Paul, once more for your feedback. Sorry I missed these in the EAP forum.
