I am working on a project where I need to place type 1 and 2 tandems on BRT. However, I can not find any existing Turnout libraries that have any already available. Does anyone know where I could find them or how to create a new turnout in a library please?
Roger
Have you got a schematic or design standard that details the information on this tandem turnout? As far as I can see, a type 1 turnout has both switches off the mainline, while a type 2 has an additional switch off the back of the first. Not sure what we can make but the info will be the first step in finding out.
If you upload some information here we could have a look at making one
It is not so difficult to create a new turnout in the library. Just open the library and use the new button. You then have to choose the type Single, double or diamond.Of course you need the required information. The schematic button will help you to identify the parameters. The Verify button could set the geometry in the turnout but you can add/delete/edit elements using a right click on the bottom of the dialog.
