All
I received a drawing from another design house and noted a really positive thing in their plan annotation. See attached
The deisgner has put a diamond symbol in plan at the point of vertical intersection, and circular symbols at the two associated points of vertical curvature/tangency.
I have played around with the vertical change in plan tools in Power Rail Track, but have not found any way to show these points in plan as per the attachment.
How can I do this in PRT/BRT?
You can use Stationing annotation to annotate start (PVC) and end (PVT) of curves using the same symbol (circle) that you can set in Point Symbols. You must also use the vertical change in plan to annotate the VPI using a cell or symbol. You should get something close from what you received.
Answer Verified By: Alastair Hume
This is just the job - completley forgot to look at stationing tools for this. Thanks
a
