Dear All,
In end area volume , how to get cut and fill quantities for individual components .
For example , in the attached image how to calculate
1.Green component ( Style given : Blanket ) quantity in cut and fill
2.Yellow component ( Style given :Sub grade) quantity in cut and fill
Thank you in advance ,
Bala
I don't see any easy way to get it, except the long one which is to measure the area manually. The automated way would be to create components as you want to calculate them. Probably not straightforward but achievable.May I ask why you need such quantities ? Once the existing is excavated you will only have fill/layer material.
Answer Verified By: Bala Vignesh
Thank you for your reply.
It is as per client requirement .
