All
Finally got my hands on ORLD CE 10.06.00.36 (but I think the newest release ends with 42)
Really simple question - how can I define turnouts. Our turnout definitions are currently in XML, so the first step is to be able to convert the XMl to feature definitions for use with the new software - no idea how to do this :)
Second thing is, I have some custom turnouts that I decided to define manually in the software, but for some reason I cannot show the turnout branch tab in the turnout properties. see attached image.
What am I doing wrong?
Would appreciate any help
A
Hi Alastair, there's a keyin to convert XML turnouts - RAIL TURNOUT IMPORT
I'm not sure about your second query, maybe someone from Bentley can chip in...
Cheers,
Paul
Cheers Paul - that got the turnout REPWs into my DGNLIB, but still cant show the menu item in the properties to edit the elements and lead for example. Weird
Did you open the dgnlib file and it has read/write access ?
It is a defect. Should be fixed in next release. Workaround is to start from a copy of an existing with the same number of elements in the branch.
I have managed to import our turnouts from XML. When I annotate the TO with Drawing Production>Annotate Element the Remove Element Annotation doesn't work. So I have to use Remove Model Annotation. Is this a known problem?
Now I want to change the TO annotation style. How do I go about doing this?
Neville du Plessis
Rail Design
