How to use On alignment and Off alignment points to import horizontal alignment
Dear Designer
When i'm trying to import horizontal alignment via" text import wizard" in step 4 , "Column Data format" drop down box appears .
In which we can able to select the different types of attributes that PI can be assigned .
In the list we have two options which are "On alignment point " and "Off alignment point" , for which the exact use can't be found out from help.
It will be really helpful if this two options are know what they mean.
Note:Attached can be used to visualize the exact query .
Thanks in advance ,
Bala
