Hi All,
I want to get "F" as a suffix for fall and "R" as a suffix for rise instead of "-" Sign for fall and nothing for rise in grade and length or vertical alignment annotation in profile and in vertical change in plan.
For example: 1: 200 F inplace of 1:-200 and 1: 200 R inplace of 1:200 only.
Thanks in advance!
Yamini
Could you try using Microstation/PRT find and replace tool after you create your annotation? Could find all instances of "-" in your profile and replace it with "F" for example. The fence tools would allow you to specify an area to run this replacement in, if you dont want to do it globally throughout the file.
A
Alastair
Doing so I will be able to replace "-" with "F" like 1:-200 will be 1:F200 but I want it as 1:200 F
You can add a + for positive slope by setting the variable in the variable manager. But anyway I don't see an easy way to achieve what you want. We don't have separate entries for positive and negative slope annotations
