All
Can anyone provide me with an existing Annotation Group XML or a dgnlib file containing an Annotation Group that shows Rail specific profile frame annotation.
I am trying to set up ORLD and am making use of the example workspaces provided with the product, but things like cant alignment, cant points, and other rail specific profile frame annotation is tricky to set up - so much so that everything I try shows a blank frame for these cant related items.
Would appreciate any help
ThanksA
Did you try using the latest release, just published on Thursday ? There is a Rail Framed Profile annotation that looks good.
jpln I havent got immeadiate access to the next release as soon as it is live. Our software team is only aware of release 1. Is it possible to share the XML for me to import and see?Thanks
Alastair
Not sure it will work because of scheme that can change from a version to another. Downward compatibility never assured.
There is an issue with the speed annotation (defect logged): only m/s even displayed with suffix kphAnnotationDefinitions.zip
Thanks very much jpln
Will have a look and let you know how it goes
A
