All
I am working to set up some Feature Definitions and DGNLIBS for use with our company in OpenRail Designer Connect Edition.
Throughout the testing process, in my Work in Progress DGNLIB, I have created, amended and deleted many alignments and elements in an effort to test and create the correct resource for us to use.
Througout this process, a number of "invalid" element warnings are being displayed in my design view. These are red circles with an "X" through them, that scale with zooming in and out.
I cannot find a way to remove these.
I have emptied my model such that nothing is being shown in the "OpenRail Model" tab. I deleted all elements, I have compressed the file. Nothing seems to work to remove these.
Is there a way!?
Any help would be appreciated
A
Hi;
Can you share the model so we can check?
Kivanch Please see attached.
Rail_2018_Feature Definations.dgnlib
from the keyin, type Civil Display Browser
Then select the glyph (red circles with an "X" ) and from the ObjectSpace Browser toolsbar find and use Identify Tree node for Selected Geometry. You should jump on a line starting with this same symbol. Righ click on the line and delete. confirm deletion.It should work as I did it on your file.
I also noticed what appears as a bad element Track Sleeper in the 3d model. I selected all and found one element out of range. I deleted in from the Properties dialog (right click on the element).
