The latest update 4 10.04.00.48 lets build both turnout and crossover geometry, then the sleepers from the main track are updated but i am having problems to wide the ballast shape and the other components of secondary track, any video or help for doing?
You must control points of your template using branch geometry. So you need a template that includes main+branch and apply it along the turnout. Main line is usually the reference. Then add a point control to the edge of the ballast (and/or subballast depending on the template behavior) to follow the geometry of the branch. You can also define the branch as a secondary alignment, a quick way to be a little more accurate for the external part of the branch. You can find templates such as "single track - Siding left (or right) in the delivered template library that are made for such design.
