Can someone please advise how to get the horizontal and vertical skews reported at the design chainage please.
My designer says there isnt a way to do it but I don't agree..
Go to the geometry tab on the ribbon and select the drop down on "Reports". Choose "Station Base Report" from the drop down. Select your design alignment, select the feature you want to report offsets on. Set the interval in the box. Right click to run the report. Look at your StationBaseSingle and your StatoinBaseVerticalClearance report. Check out the other reports if you need additional data.
