Dear All,
According to my knowledge and information located on this forum which I have found till now there is no possibility to view rate of change of cant or rate of change of cant deficency automatically on plan view in RailTrack SS2.
Can someone confirm or tell how to do that?
Thanks in advance!
GH
Grzegorz
In the UK, we generally annotate element information and cant information in plan, over the centre of our alignment.
Linear - Speed, Length, Applied Cant, Cant deficency
Curves - Speed, Radius, Applied Cant, Cant deficency
Transitions - Transition length, speed, Rate of Change of Cant, Rate of Change of deficency
To do this - we use an Application Add In built in to BRT. If you go to - Tools - Application Add Ins and tick the box beside "Network Rail Exteisions Add-In" this enables this.
Then if you go to Drafting - Network Rail Extensions - Display Switches and Crossings, in the "Horizontal" tab, you can define the symbologies of how you want to the plan annotation to be displayed. See the images below for how I have defined my annotation and how it appears in plan. You can also annotate S&C if it has been defined in a particular way. Check the Help for information on this add in.
A
Answer Verified By: Grzegorz Honkisz
Will check that shortly - thank you very much!
