Hello
I'm trying to create cross sections using the named boundaires tool in ORD. I can create the sections in the 3d model and everything is fine until click the create cross section drawing icon.... nothing happens and i get an error at the bottom of the page saying my group i just create and selected in not found. any solutions???? I have a similar issue with the profile
Solved I had to bring my project off our server and save to my c drive to simplify the file path, then it worked fine
Answer Verified By: Bryce Hourigan
There is a defect looged for this issue: Defect 899714:Can't create Civil Drawing if path contains a comma or dot.
