I have two questions about terrain model in ORD:
1) How can I set a max triangle length in existing terrain?
2) In 3D view - I want to see only triangle edges in existing terrain (without green fill inside triangles), is there any possibilty to do this?
DR
1- this is a property of the terrain model. Instead of using slivers you can use max triangle length and set the length.
2- if you set the view display style as wireframe you should not get the fill inside triangles.
Answer Verified By: Damian Rypel
1 - There is an option in terrain model (edge method) but it didn't work with terrain created from file (dtm). But now everything is working correctly - it turned out that I didn't import features (I was using option "import terrain only").
2- The solution works perfectly
if you import the terrain model from a dtm you may have the edge method locked to "from boundary". If it is the case and you want to change, you can remove the boundary. There is a command in the terrain ribbon to create/remove boundary.
